Disabling LLDP globally
To globally disable LLDP, perform the following steps:
  1. From privileged EXEC mode, access global configuration mode.
    device# configure terminal
  2. Access LLDP configuration mode.
    device(config)# protocol lldp
  3. Disable LLDP globally.
    device(config-lldp)# disable
  4. Verify the configuration.
    device(config-lldp)# do show running-config protocol lldp
    protocol lldp
     system-description Extreme BR-SLX9540 Router
     disable
The following configuration is an example of the previous steps to disable LLDP.
If required, re-enable LLDP.
device(config-lldp)# no disable
