TVPM address assignment
TPVM has Ethernet 0 and 1 interfaces. Ethernet 0 (eth0) is enabled and its IP address is configured using DHCP.
On the SLXVM, the show tpvm ipaddr command configures the address.
If DHCP is not available, you can use the serial console to login. Use 'extreme' as the user name and 'password' as the password. You can then use standard Ubuntu (18.04 LTS) commands to configure the IP address of the 'eth0' interface.
eth1 is connected to the Insight interface and allows packet monitoring.
