Setting the clock
To set the clock, perform the following step:
  1. In privileged EXEC mode, set the current date and time in the UTC timezone.
    This must be set to the UTC time, otherwise configuration of the timezone will cause the system to adopt the incorrect local time.
    device# clock set 2019-12-10T16:38:00
    This example sets the time and date to 16:38:00 on December 10, 2019.
    Setting the clock is not required whtn NTP is configured and the clock is synchronized to an external NTP server.
  2. Enter global configuration mode.
    device# configure terminal
  3. Change the time zone.
    device(config)# clock timezone America/Los_A
    device(config)# end
    device# show clock
    2019-12-10 08:38:18 America/Los_Angeles
    device#
    This example changes the time zone to the region of America and the city of Los Angeles.
The following configuration is an example of the previous steps.
device# conf
Entering configuration mode terminal
device(config)# end
device# show clock
device#
