To set the parameters, perform the following steps:
  1. In privileged EXEC mode, set the display length.
    device# terminal length 30
    This example sets the lines to be displayed on the terminal session at 30 lines.
    Setting the terminal length to 0 removes page breaks for the show commands' output.
  2. Set the timeout length.
    device# terminal timeout 3600
    This example sets the timeout of 3600 seconds (60 minutes) for the terminal session.
    Specifying a value of 0 allows the terminal session to stay open until the device is rebooted or the connection is terminated by other means.
  3. Access global configuration mode.
    device# configure terminal
  4. Configure the maximum login attempts to establish a session.
    device(config)# password-attributes max-retry 4
    This example sets the maximum login attempts of four to establish a session.
  5. Set the maximum number of minutes the user account remains locked when user fails to login within the maximum login attempts.
    device(config)# password-attributes admin-lockout max-lockout-duration 5
    This example specifies that the user account be unlocked after 5 minutes.
The following configuration is the example of the previous steps.
