  1. Enter global configuration mode.
    device# configure terminal
  2. Create an extended Layer 2 ACL.
    device(config)# mac access-list extended macl
  3. Configure the Layer 2 ACL for mirroring.
    device(conf-macl-ext)# seq 10 permit host 0010.9400.0010 host 0010.9400.0014 vlan 20 count mirror
    device(conf-macl-ext)# seq 20 permit host 0010.9400.0011 host 0010.9400.0015 vlan 20 count mirror
    device(conf-macl-ext)# seq 30 permit host 0010.9400.0012 host 609c.9f01.58cb vlan 21 count mirror
    device(conf-macl-ext)# seq 40 permit host 0010.9400.0013 host 609c.9f01.58cb vlan 22 count mirror
    device(conf-macl-ext)# seq 50 permit any any count mirror
  4. Return to global configuration mode.
    device(conf-macl-ext)# exit
  5. Create an extended IPv4 ACL.
    device(config)# ip access-list extended ipv4acl
  6. Configure the IPv4 ACL for mirroring.
    device(conf-ipv4acl-ext)# seq 10 permit ip host 11.12.13.14 any count mirror
  7. Return to global configuration mode.
    device(conf-ipv4acl-ext)# exit
  8. Associate the ACL destination mirror port.
    device(config)# acl-mirror source ethernet 0/1 destination port-channel 1
  9. Enter configuration mode for the source mirror port.
    device(config)# interface ethernet 0/4
  10. Bind the Layer 3 IP ACL to the source mirror port.
    1. Bind the Layer 2 ACL to the source mirror port.
      device(conf-if-eth-0/1)# mac access-group mac1 in
    2. Bind the IPv4 ACL to the source mirror port.
      device(conf-if-eth-0/1)# ip access-group ipv4acl in
  11. Return to privileged exec mode.
    device(conf-if-eth-0/1)# end
  12. Verify the configuration.
    device# show statistics access-list interface ethernet 0/1 in
    mac access-list macl on Ethernet 0/1 at Ingress (From User)
        seq 10 permit host 0010.9400.0010 host 0010.9400.0014 vlan 20 count mirror (105555094236 frames)
        seq 20 permit host 0010.9400.0011 host 0010.9400.0015 vlan 20 count mirror (105555103123 frames)
        seq 30 permit host 0010.9400.0012 host 609c.9f01.58cb vlan 21 count mirror (105555072247 frames)
        seq 40 permit host 0010.9400.0013 host 609c.9f01.58cb vlan 22 count mirror (105555083432 frames)
        seq 50 permit any any count mirror (0 frames)
  13. Save the configuration.
Inbound ACL-based mirroring to the insight interface configuration example (Layer 2)
device(config)# interface ethernet 0/1
Only the Layer 2 ACL creation is shown in this example.
