Port transition hold timer
While link down events are reported immediately in the Syslog, their effect on higher level protocols such as OSPF is delayed according to how the hold timer is configured. When configured, the timer affects the physical link events. However, the resulting logical link events are also delayed.
All LAG member ports must have the same delayed-link-event configuration.
The delayed-link-event configuration is applicable only on a physical interface. It is not valid on a VLAN, VE, LAG, or loopback interfaces.
The port transition hold timer does not take effect when the interface is administratively shut down.
