ARP Proxy
Tunnel Concentrator supports ARP Proxy by default. Tunnel Concentrator stores its own local ARP lookup table and can proxy and respond to ARP requests. This feature is enabled by default. However, with ExtremeCloud IQ-managed deployments, you can disable the feature.
Disabling ARP Proxy may cause ARP requests to flood to APs, resulting in significant ARP broadcast traffic. Use with caution.
To update its ARP table, Tunnel Concentrator uses the following logic:
To respond to ARP requests, Tunnel Concentrator does a lookup of its ARP table for a MAC address that maps to the target IP address from the ARP request and responds as per these rules:
