Installation Task Flow
Complete the tasks in the following flow to complete the installation and initial setup of Tunnel Concentrator on the Universal Compute Platform.
Before you Begin
Review Installation Prerequisites and make sure that you meet the full list of requirements for your deployment.
Table 1. Installation Task Flow
ProcedureDescription
1Install ExtremeCloud Edge-Self-Orchestration DeploymentInstall an ExtremeCloud Edge - Self-Orchestration deployment on Universal Compute Platform.
2Upload Tunnel Concentrator ImageUpload Tunnel Concentrator image to Universal Compute Platform.
3Install Tunnel ConcentratorInstall the Tunnel Concentrator application on Universal Compute Platform.
4Change Default Admin PasswordAs a best practice, change the default admin password immediately following the first login.
5Generate the Activation LicenseActivate the license for your installation.
6Select the Management Option
Select the management application for tunnel provisioning:
  • ExtremeCloud IQ
  • ExtremeCloud IQ Controller
For an installation example with sample settings, see Installation Example.
