Edit Tunnel Concentrator Hostname
Use this optional procedure to change the hostname of a Tunnel Concentrator instance that is managed from ExtremeCloud‌ IQ.
  1. On ExtremeCloud IQ (Classic), go to Manage > Devices.
  2. From the devices list, select the host name of the applicable Tunnel Concentrator instance.
    The Device Details page opens for the Tunnel Concentrator instance.
  3. Select the Configure tab.
  4. From the Configuration menu, select Device Configuration.
  5. Edit the value of the Host Name field.
  6. Select Save Device Configuration.
