Change Default Admin Password
Use this procedure to change the default admin password for the Tunnel Concentrator user interface.
As a best practice, change the admin password immediately after you login for the first time.
  1. Log in to the Tunnel Concentrator user interface using the default admin credentials.
  2. Select (User Actions icon) from the top right of the header.
  3. Select Change Password.
  4. In the Password box, enter the new admin password.
  5. In the Confirm Password box, re-enter the new admin password.
  6. Select Update.
