Configure Packet Captures
From the Diagnostics menu, configure a packet captures that captures traffic on all active ports.
  1. Log in to Tunnel Concentrator.
  2. Go to Tools > Diagnostics.
  3. Under Packet Capture, enter the Filename to use for saved the packet capture file.
  4. Drag the scrollbar until you reach the desired maximum for the number of packets to capture.
  5. To start the packet capture, select START.
  6. To stop the packet capture, select STOP.
    Captured files display under Capture Files. To download a file capture, hover your cursor over a captured file and select the Download icon.
A TZSP header is added to the beginning of each frame in the capture file. Port and RX/TX information will be visible in the TZSP “Capture Location” tag.
