Use this procedure to upgrade a Tunnel Concentrator application instance from the Universal Compute Platform user interface. This procedure upgrades the application while retaining existing settings. There is no need to stop or uninstall the existing application instance.
Download the new Tunnel Concentrator install image from the Extreme Networks Support Portal atDownloads/ExtremeCloud/Extreme Tunnel Concentrator.
To delete an image file, select the adjacent check box and then select
