Configure Tunnel Policy
Use this optional procedure to configure a tunnel policy that points to your Tunnel Concentrator service. If you want Layer 2 roaming, you can use the policy to quickly provision Tunnel Concentrator across multiple user profiles in different SSIDs.
The Tunnel Policy is not a mandatory configuration as you can assign a Tunnel Concentrator service to a user profile directly.
  1. On ExtremeCloud IQ (Classic), go to Configure > Common Objects > Network > Tunnel Policies.
  2. Do one of the following:
    • Select an existing tunnel policy.
    • Select (Add) to create a new tunnel policy.
  3. Enter a Name for the policy.
  4. Select Tunnel Concentrator.
  5. For Tunnel Destination, select the Tunnel Concentrator service that you want to apply to this policy.
  6. Select Save.
Tip
Tip
Apply this Tunnel Policy to one or more User Profiles to apply the policy's Tunnel Concentrator settings to the profile automatically.
