The 2000 W AC PSU-FB (models XN-ACPWR-2000W-FB and XN-ACPWR-2000W-F with front-to-back ventilation airflow) are compatible with VSP4900-48P and VSP4900-12MXU-12XE switch models that have the same airflow direction as the power supply.
In order to obtain 2000W output from this power supply, the PSU must be connected to a 200-240VAC source.
The ExtremeSwitching 2000 W AC power supply has a keyed power inlet (C16) that requires a notched (C15) power cord.
The ExtremeSwitching 2000 W AC power supply has the status LEDs listed in the following table:
IN_OK (Green) |
OUT_OK (Green or Red) |
Description |
Off |
Off |
No AC input power connection or low AC voltage. |
On |
Off |
AC input good, 54V output disabled. |
On |
(Red) On |
AC input good, output (54V) fault. |
On |
(Green) On |
AC input good, DC outputs in spec. |
