To remove or reposition a switch after you have mounted it in a rack, follow these steps.
These procedures assume that you have attached the switch to the rack as described in Installing a Switch.
For two-post installations, carefully slide the switch out of the rack.
For four-post installations, carefully slide the switch forward out of the cabinet and off the rear mounting brackets.
See the following figures.
If you plan to use the switch again later, we recommend storing it with the mounting brackets attached.
