The VIM5-4Y versatile interface module provides four 25-GbE (SFP28) ports.
For VSP4900-48P and VSP4900-24S, only the first two 25-GbE (SFP28) ports are supported.
The VIM5-4Y can be configured to provide four 10GbE ports using the port partitioning CLI. For details about the configure ports partition command, see the Command Line Interface Commands Reference for VOSS.
For information about the supported optical modules, refer to the most recent version of the Extreme Hardware/Software Compatibility and Recommendation Matrices.
ExtremeSwitching VSP 4900 port number for 24-port models |
ExtremeSwitching VSP 4900 port number for 48-port models |
25-28 |
49-52 |
