The VIM5-4YE versatile interface module provides four 25-GbE (SFP28) LRM/MACsec capable ports.
For VSP4900-24S, only the first 25-GbE (SFP28) port is supported.
For VSP4900-48P, VSP4900-24XE, and VSP4900-12MXU-12XE, only the first two 25-GbE (SFP28) ports are supported.
You must set sys vim-speed to 10G or 25G for VIM5-4YE. The default is 25G. A reboot is not necessary after setting the speed. For details about the sys vim-speed command, see the Command Line Interface Commands Reference for VOSS.
For information about the supported optical modules, refer to the most recent version of the Extreme Hardware/Software Compatibility and Recommendation Matrices.
ExtremeSwitching VSP 4900 port number for VSP4900-24S |
ExtremeSwitching VSP 4900 port numbers for VSP4900-48P, 24XE, and 12MXU-12XE models |
2/1 |
2/1, 2/2 |
