There are two supported modes for ExtremeSwitching VIM5 port LEDs:
In the default SYS mode, SPD is OFF, and the port status will display behavior for link, traffic, and PoE as described in the following table:
Color/State |
Meaning |
Steady green |
Link is OK; port is not powered |
Blinking green |
Link is OK and transmitting packets; port is not powered |
Slow blinking green |
Port is admin disabled |
Off |
Port is not powered, has no link |
SPD mode is used to help determine the operational speed of a port. Color and blink pattern indicate speeds, as referenced by the following table:
Color/State |
Speed |
Steady green |
10Gbps |
Blinking green |
40Gbps |
Steady amber |
1Gbps |
Blinking amber |
25Gbps |
For the VIM5-2Q, the two LEDs in the QSFP+ cage are not supported/used, only the two sets of LEDs numbered L1-L4 on either side are supported as follows:
LED |
Mapping |
LED 1 |
represents 40G port status/speed or first 10G port‘s status/speed when channelized |
LED 2 |
status/speed for second 10G port when channelized |
LED 3 |
status/speed for third 10G port when channelized |
LED 4 |
status/speed for fourth 10G port when channelized |
