Provide enough space in front of and behind the equipment, so that you can service it easily and so that airflow is not impeded.
The equipment does not have a switch for turning power on and off. For systems using an AC power supply, power to the switch is disconnected by removing the wall plug from the electrical outlet.Be sure that cables and other equipment do not block the switch's air intake or outflow.
