You can install a VIM5 versatile interface module in a dedicated slot in the front panel of the ExtremeSwitching VSP 4900 Series switch to provide 10/25/40G dedicated high speed ports. The front panel of every VSP 4900 switch provides one slot to install the following:
VIM5-4X versatile interface module that provides four 10-GbE (SFP+) ports.
VIM5-4XE versatile interface module that provides four 10-GbE (SFP+) ports, LRM/MACsec capable.
VIM5-2Y versatile interface module that provides two 25-GbE (SFP28) ports.
VIM5-4Y versatile interface modulethat provides four 25-GbE (SFP28) ports.
VIM5-4YE versatile interface module that provides four 25-GbE (SFP28) MACsec capable ports.
VIM5-2Q versatile interface module that provides two 40-GbE (QSFP) ports.
For 24 and 48-port models, the VIM5 ports are 2/1, 2/2, 2/3, 2/4 depending on the VIM installed.
VIM5s are ordered separately. Each VIM5 label can be found on the bottom side of the device, as seen in the following figure:
1 = VIM5 label |
VIM5-4X |
VIM5-4XE |
VIM5-2Y |
VIM5-4Y |
VIM5-4YE |
VIM5-2Q |
Usable ports (VSP4900-48P and VSP4900-24S) |
4 |
4 |
2 |
2 |
2 |
1 |
Usable ports (VSP4900-24XE and VSP4900-12MXU-12XE) |
4 |
4 |
2 |
4 |
4 |
2 |
Operational speeds |
1Gbps & 10Gbps |
1Gbps & 10Gbps |
10Gbps & 25Gbps |
10Gbps & 25Gbps |
10Gbps & 25Gbps |
4x10Gbps w/channelization & 40Gbps |
PHY present |
No |
Yes |
Yes |
Yes |
Yes |
No |
1000BASE-T & 10GBASE-T |
10GBASE-T only |
Both |
10GBASE-T only |
10GBASE-T only |
10GBASE-T only |
Mixed speeds |
1Gbps & 10Gbps |
1Gbps & 10Gbps |
Not supported* |
Not supported* |
Not supported* |
1G Auto-negotiation |
Disabled |
Enabled |
10G Auto-negotiation |
Disabled |
Disabled |
Disabled |
Disabled |
Disabled |
25G Auto-negotiation |
Disabled |
Disabled |
Enabled for DAC Disabled for Fiber |
FEC |
Not supported |
Not supported |
Not supported |
Not supported |
Auto-FEC enabled for DAC and Fiber |
Not supported |
MACsec |
Not supported |
128/256bit |
Not supported |
Not supported |
128/256bit |
Not supported |
* You must set sys vim-speed to 10G or 25G for VIM5-2Y and VIM5-4YE. The default is 25G. A reboot is not necessary after setting the speed.
See Versatile Interface Modules (VIM5) Port LEDs for VIM5 LED details.
