Extreme Networks does not include power input cords in the product box.
You can purchase a power cord for your product and for your specific country from your local Extreme Networks Channel Account Manager or Sales Manager, or you can purchase a cord from your local supplier. Requirements for the power cord are listed in the Technical Specifications for your product.
To locate a Sales Manager or Partner in your region, visit www.extremenetworks.com/partners/where-to-buy.
This equipment is not intended to be directly powered by power distribution systems where phase-phase voltages exceed 240 VAC (2P+PE), such as those used in Norway, France, and other countries. For these applications, use a transformer to step down the voltage to < 240 VAC from phase-phase, or make a connection to a (P+N+PE) power distribution where voltages do not exceed 240 VAC.All installations should confirm that the product is reliably grounded according to the country‘s local electrical codes.
