The ExtremeSwitching 2000 W AC power supplies with part numbers XN-ACPWR-2000W-FB and XN-ACPWR-2000W-F are compatible with VSP4900-48P and VSP4900-12MXU-12XE models.
These switches have two bays for hot-swappable power supplies. In a switch with a redundant power configuration, you can replace one Summit or ExtremeSwitching AC power supply without powering down the switch.
You need the following tools and materials to replace an ExtremeSwitching 2000 W AC power supply:
To replace an ExtremeSwitching 2000 W AC power supply, follow these steps:
Caution
Power supplies can become very hot during operation. Wear thermal protective gloves when you remove a power supply from an operating switch.
If you are not installing a replacement power supply, install a cover over the unoccupied power supply bay. Unoccupied bays must always be covered to maintain proper system ventilation and EMI levels.
Caution
Do not slam the power supply into the switch.
Warning
Always be sure that the source outlet is properly grounded before plugging the AC power cord into the AC power supply.
