Remove Switches from Service
Removing a switch from service is a two-step process:
- Disconnect the switch from its power source, following these steps as applicable:
- Disconnect and remove the switch's removable
AC power supply. See "Adding or Replacing Power Supplies, Fans, and
Expansion Modules."
- Disconnect the switch from its redundant power supply.
- Remove the switch from the rack, following the
steps in Remove the Switch from the Rack.
Read the information in this chapter thoroughly before you
attempt to remove a switch.
