The VIM5-2Y versatile interface module provides two 25-GbE (SFP28) ports.
You must set sys vim-speed to 10G or 25G for VIM5-2Y. The default is 25G. A reboot is not necessary after setting the speed. For details about the sys vim-speed command, see the Command Line Interface Commands Reference for VOSS.
For information about the supported optical modules, refer to the most recent version of the Extreme Hardware/Software Compatibility and Recommendation Matrices.
ExtremeSwitching VSP 4900 port number for 24-port models |
ExtremeSwitching VSP 4900 port numbers for 48-port models |
2/1, 2/1 |
2/1, 2/1 |
