VSP 4900 Series includes the following switches:
VSP4900-48P switch
VSP4900-12MXU-12XE switch
VSP4900-24S switch
VSP4900-24XE switch
VSP4900 (all models) |
Height: 1.72 inches (4.36 cm) Width: 17.34 inches (44 cm) Length: 19.23 inches (48.8 cm) |
VSP4900-48P switch |
17.38 lb (7.88 kg) |
| VSP4900-12MXU-12XE switch | 16.67 lb (7.56 kg) |
VSP4900-24S switch VSP4900-24XE switch |
17.21 lb (7.81 kg) |
Height: 6.22 inches (15.8 cm) Width: 21.58 inches (54.8 cm) Length: 23.39 inches (59.4 cm) |
21.63 lb (9.81 kg) |
| VSP4900-12MXU-12XE switch | 21.48 lb (9.75 kg) |
22.02 lb (9.99 kg) |
| VIM5 Module | Weight | Dimensions |
| VIM5-2Q | 0.40 lb (0.18 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-2Y | 0.42 lb (0.19 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-4Y | 0.47 lb (0.21 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-4X | 0.40 lb (0.18 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-4XE | 0.45 lb (0.20 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-4YE | 0.47 lb (0.21 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-2Q | 17.02 lb (7.72 kg) | Height: 9.21 inches (23.39 cm) Width: 18.54 inches (47.01 cm) Length: 21.26 inches (54 cm) |
| VIM5-2Y | 17.42 lb (7.90 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-4Y | 18.77 lb (8.51 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-4X | 17.06 lb (7.74 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-4XE | 18.14 lb (8.23 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| VIM5-4YE | 18.77 lb (8.51 kg) | Height: 1.57 inches (3.99 cm) Width: 1.92 inches (4.88 cm) Length: 6.16 inches (15.64 cm) |
| Switch Model | Ambient Temp | VIM | PoE | Main Fan Speed (% of max) | PSU1 + PSU2 | Bystander Sound Pressure | Declared Sound Power (LWAd) |
| VSP4900-48P switch | 25°C | VIM5-4XE | 720W | 20% | 1100W (½ of max PoE power | 45.8 | 56.6 |
| VSP4900-12MXU-12XE Switch | 25°C | None | 720W | 30% | 1450W (½ of max PoE power | 50.3 | 55.1 |
VSP4900-24S switch |
25°C | None | None | 30% | 350W | 49.5 | 56.2 |
25°C | None | None | 30% | 350W | 49.9 | 56.8 |
Note: *Power Supply fans at 100%
Note: Acoustic noise
levels shown here represent noise emitted by the switch at room
ambient temperatures. Values are based on a fully configured
system consisting of two PSUs and two I/O modules operating
under full load. Normal operating temperature range: 0°C to
50°C.
The speed of the fan increases only when the temperature of the device increases. Fan speed is not dependent on any fan failures.
| Fan Speed | Fan Module RPM (typical) | Power | ||
| Inlet Fan | Outlet Fan | Typical | ||
| Full | 16,000 (typ) | 13,500 (typ) | 15.8W per module* | |
| Low | 3,200 (typ) | 2,800 (typ) | ||
* Some units are equipped with (1) fan module, while others are equipped with 2. Total fan power is equal to the number of installed fan modules multiplied by the fan power for each module.
| Switch Model | Power Supply |
350
W AC power supply: Part nos. XN-ACPWR-350W-FB and 10953 350 W AC PS FB (front-to-back) Model PSSF351101A 100-240 V 50/60 Hz, 1.25 A max per PS |
VSP4900-48P switch VSP4900-12MXU-12XE switch |
715
W AC power supply: Part nos. XN-ACPWR-715W-FB and 10951 715 W AC PS FB (front-to-back) Model PSSF711101A 100-127 V 50/60 Hz, 5.75A/2.75 A max per PS |
1100 W AC power supply: Part nos. XN-ACPWR-1100W-FB and 10941 1100 W AC PS FB (front to back), Model PSSF112101A 100-127 V 50/60 Hz, 10.5A/5.0 A max per PS |
2000 W AC power supply: Part nos. XN-ACPWR-200W-FB and XN-ACPWR-200W-F 2000 W AC PS FB (front to back), Model 100-127 V 50/60 Hz, 11.5A/5.5 A max per PS |
XN-ACPWR-xxx-FB PSUs cannot be used with the 10941, 10951, 10953, or XN-ACPWR-2000W-F PSUs on the same switch.Previous software versions are not supported with XN-ACPWR-xxx-FB PSUs. You must upgrade to the listed minimum software version or later to use any of the XN-ACPWR-xxx-FB PSUs with the switch.
The following table lists supported PSU combinations when dual redundant PSUs are used on the switch.
Refer to the 5520 datasheet for appropriate PSUs for the switch.
| Switch Model | Primary PSU | Secondary PSU |
| Non-PoE models |
XN-ACPWR-350W-FB |
XN-ACPWR-350W-FB |
| PoE models |
XN-ACPWR-715W-FB or XN-ACPWR-1100W-FB or XN-ACPWR-2000W-FB |
| Switch Model | Minimum Heat Dissipation (BTU/hr) | Minimum Power Consumption (W) | Maximum Heat Dissipation (BTU/hr) | Maximum Power Consumption (W) |
280 | 82 | 1046 | 1746 |
250.1 | 73.33 | 854 | 970.29 |
178.5 | 52.3 | 589.5 | 172.7 |
271.4 | 79.5 | 707.5 | 207.3 |
| Switch Model | 1 x 1100W PSU | 2 x 1100W PSU |
| VSP4900-48P | 845W | 1440W |
| VSP4900-12MXU-12XE | 845W | 1440W |
| CPU/Memory | |
| VSP4900-48P, VSP4900-24S | VSP4900-24XE , VSP4900-12MXU-12XE |
| 2-core, 1.5GHz x86 CPU | 4-core, 2.1GHz x86 CPU |
| 2 GB DDR4 memory | 8 GB DDR4 memory |
| 8 GB eMMC Flash Memory | |
| 12MB packet buffer per chip | |
North American Safety of ITE |
UL 60950 UL 62368-1 CAN/CSA-C22.2 No. 62368-1 CSA 22.2 No. 60950-1 Complies with FCC 21CFR 1040.10 (US Laser Safety) CDRH Letter of Approval (US FDA Approval) |
European Safety of ITE |
IEC 60950-1 EN 60950-1 EN 60825-1 IEC/EN 62368-1 EN 62368-1 |
International Safety of ITE |
CB Report & Certificate per IEC 60950-1 + National Differences AS/NZX 60950-1 (Australia /New Zealand) |
North America EMC for ITE |
FCC CFR 47 part 15 Class A (USA) ICES-003 Class A (Canada) |
European EMC standards |
EN 55032:2015+AC:2016, Class A EN 55024:2010+A1:2015 Class A includes IEC 61000-4-2, 3, 4, 5, 6, 11 EN 61000-3-2:2014 (Harmonics) EN 61000-3-3:2013 (Flicker) ETSI EN 300 386 V2.1.1 (2016-07) (EMC Telecommunications) 2014/35/EU Low Voltage Directive |
International EMC certifications |
CISPR 32: 2015, Class A (International Emissions) EN 55024 EN 55024:2010+A1:2015 Class A (International Immunity) IEC/EN 61000-4-2:2008 Electrostatic Discharge, 8kV Contact, 15 kV Air, Criteria A IEC/EN 61000-4-3-4-3:2010 Radiated Immunity 10V/m, Criteria IEC/EN 61000-4-4-4-4:2012 Transient Burst, 1 kV, Criteria A IEC/EN 61000-4-5-4-5:2014 Surge, 2 kV L-L, 2 kV L-G, Level 3, Criteria A IEC/EN 61000-4-6-4-6:2013 Conducted Immunity, 0.15-80 MHz, 10V/m unmod. RMS, Criteria A IEC/EN 61000-4-11:2004 Power Dips & Interruptions, >30%, 25 periods, Criteria C |
Country-specific |
VCCI Class A (Japan Emissions) BSMI (Taiwan Emissions) ACMA (C-Tick) (Australia Emissions) CCC Mark (China) KCC Mark, EMC Approval (Korea) |
EN/ETSI 300 386 EN 300 386 V2.1.1 (2016-07) (EMC Telecommunications) EN/ETSI 300 019 (Environmental for Telecommunications) MEF9 and MEF14 certified for EPL, EVPL, and ELAN |
IEEE 802.3ab 1000BASE-T IEEE 802.3z 1000BASE-X IEEE 802.3ae 10GBASE-X IEEE 802.3ba 40GBASE-X IEEE 802.3bz 2.5GBASE-T and 5GBASE-T (for X460-G2-16mp-32p-10GE4) IEEE 802.3at PoE Plus IEEE 802.3az (EEE) |
Environmental standards |
EN/ETSI 300 019-2-1 v2.1.2 (2000 - 2009) - Class 1.2 Storage EN/ETSI 300 019-2-2 v2.1.2 (1999 - 09) - Class 2.3 Transportation EN/ETSI 300 019-2-3 v2.1.2 (2003 - 04) - Class 3.1e Operational EN/ETSI 300 753 (1997-10) - Acoustic Noise ASTM D3580 Random Vibration Unpackaged 1.5G |
Operating conditions |
Temperature range: 0°C to 50°C (32°F to 122°F) Humidity: 10% to 95% relative humidity, non-condensing Altitude: 0 to 3,000 meters (9,850 feet) Operational shock (half sine): 30 m/s2 (3 G), 11 ms, 60 shocks Operational random vibration: 3 to 500 Hz at 1.5 G rms |
Storage & transportation conditions (packaged) |
Transportation temperature: -40°C to 70°C (-40°F to 158°F) Storage and transportation humidity: 10% to 95% relative humidity, non-condensing Packaged shock (half sine): 180 m/s2 (18 G), 6 ms, 600 shocks Packaged sine vibration: 5 to 62 Hz at velocity 5 mm/s, 62 to 500 Hz at 0.2 G Packaged random vibration: 5 to 20 Hz at 1.0 ASD w/–3 dB/oct. from 20 to 200 Hz 14 drops minimum on sides and corners at 42 inches (<15 kg box) |
