The 715 W AC power supplies with front-to-back airflow (part nos. XN-ACPWR-715W-FB and 10951) are available for use in VSP4900-48P and VSP4900-12MXU-12XE model switches.
Dimensions |
Height: 1.57 inches (4.0 cm) Width: 3.25 inches (8.3 cm) Length: 10.22 inches (26.0 cm) |
Weight |
2.55 lb (1.12 kg) |
Voltage input range |
100-127/200-240 |
Nominal input ratings |
12.5 A max at 115VAC and 6A max at 230VAC at Full 715 W load |
Maximum inrush current |
45A at Max 264 VAC at 25C with cold start |
Output |
54 V, 13.2 A max, 715 W |
Power supply input socket and cord |
IEC/EN 60320-1/C16 AC input receptacles |
Power cord wall plug |
Refer to Power Cord Requirements for AC-Powered Switches and AC Power Supplies |
Efficiency |
Minimum efficiency: 88% at maximum power output |
Operating temperature |
-10°C to 50°C (normal operation) |
Storage temperature |
-40°C to 70°C |
Operating humidity |
93% relative humidity, non-condensing at 30C |
Operational shock |
30 m/s2 (3 G) |
