After your switch is connected to power and completes its power-on self-tests, it is operational. Before logging in, verify that the switch LEDs are on (solid green or blinking green) and that it is connected to a management console as described in Connect the Switch to a Management Console.
To perform the initial login and complete initial configuration tasks, follow these steps from the management console.
For example:
login: rwaWhen you are logged in with the role-based authentical level of rwa, you can configure the login and password values for the other role-based authentication levels. For details, see Quick Start Configuration for VOSS.
The switch is ready for use.
To configure security, see Configuring Security.
To configure other switch features, see Documentation Reference.
