To attach a switch to a four-post rack or a cabinet, follow
these steps.
Take care to load the rack so that it is not top-heavy. Start installing equipment at
the bottom and work up.
Attach a rack ear to one side of
the switch, screwing it into the holes so that the flange (ear) is flush with
the front of the switch for a front mount.
If you are mid-mounting the switch, set the flange
toward the back of the switch.
The following figures illustrate how to attach the brackets for two common
mounting options.
