This section describes how to install a versatile interface module (VIM) in the front
slot of a 5520 Series switch.
You need the following tools and materials to install a VIM:
Caution
Extreme
Networks VIMs are not hot-swappable. Disconnect power to the
switch before removing an installed VIM or installing a new VIM.
To install a versatile interface module, follow these steps:
Attach the ESD wrist strap to
your wrist and connect the metal end to an appropriate ground point on the
rack.
Ensure that the switch is
completely powered down.
Using two fingers, remove the
cover plate from the VIM slot.
Squeeze the sides to
release the plate, and pull down from the top to open. The plate will
remain attached at the bottom.
Removing a
slot Cover Plate (VIM slot cover shown)
Remove the new VIM from its
anti-static packaging.
Install the VIM in the
switch:
Carefully slide the VIM
module into the switch.
Insert and tighten the
retaining screws you previously removed, using the screws
provided.
Tighten
Screws on the Inserted VIM Module
1 = VIM module retaining screw locations
