After you have installed the switch and connected network cables, perform the following tasks to configure the software on the switch and prepare it for use.
Check https://www.extremenetworks.com/support/compatibility-matrices/extremecloud-hardware-support/ to see what switch models can be managed with ExtremeCloud™. If your switch is entitled for management by ExtremeCloud, you can optionally use the installation instructions at https://documentation.extremenetworks.com/extremecloud/quick_reference.
Otherwise, follow the instructions in these topics:
