The 1100 W AC power supplies with part numbers XN-ACPWR-1100W-FB and 10941 are compatible with VSP4900-48P and VSP4900-12MXU-12XE model switches.
The switches have two bays for hot-swappable power supplies. In a switch with a redundant power configuration, you can replace one AC power supply without powering down the switch.
You need the following tools and materials to replace a 1100 W AC power supply:
To replace a 1100 W AC power supply, follow these steps:
Caution
Power supplies can become very hot during operation. Wear thermal protective gloves when you remove a power supply from an operating switch.
If you are not installing a replacement power supply, install a cover over the unoccupied power supply bay. Unoccupied bays must always be covered to maintain proper system ventilation and EMI levels.
Caution
Do not slam the power supply into the switch.
Warning
Always be sure that the source outlet is properly grounded before plugging the AC power cord into the AC power supply.
