VSP 4900 Series Switches: Hardware Installation Guide
> General Safety Precautions
Published January 2024
Preface
Audience
Terminology
Providing Feedback
Getting Help
Overview of the VSP 4900 Series Switch
VSP4900-48P Switch Features
VSP4900-12MXU-12XE Switch Features
VSP4900-24S Switch Features
VSP4900-24XE Switch Features
VSP License Options
Power Supplies for Use with Your Switch
350 W AC Power Supplies
715 W AC Power Supplies
1100 W AC Power Supplies
2000 W AC Power Supply
Expansion Modules
Versatile Interface Modules for the ExtremeSwitching VSP 4900 Series Switches
VIM5-4X Versatile Interface Module
VIM5-4XE Versatile Interface Module
VIM5-2Y Versatile Interface Module
VIM5-4Y Versatile Interface Module
VIM5-4YE Versatile Interface Module
VIM5-2Q Versatile Interface Module
Solid-state Drives
Preparing to Install
Set up the Wiring Closet
Controlling the Temperature
Controlling the Humidity Level
Ground the Rack
Providing Adequate Space for the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Power Supply Requirements
Requirements for Power Cords
Select a UPS
Installing a Switch
Safety Considerations for Installing Switches
Installing Optional Components
Installing Internal AC Power Supplies
Selecting Power Cords for AC Power Supplies
Install a 350 W, 715 W, 1100 W, or 2000 W Internal AC Power Supply
Turn on the Switch
Activating and Verifying the Switch
Connect the Switch to a Management Console
Configure the Switch for Use
Installing Expansion Modules
Install a Versatile Interface Module in a 5520 Series Switch
Install an SSD Module
Remove Switches from Service
Remove the Switch from the Rack
Removing and Replacing Components
Replace a 350 W or 715 W AC Power Supply
Replace an 1100 W AC Power Supply
Replace a 2000 W AC Power Supply
Replace Fan Modules
Replace a VIM or SSD in a VSP 4900 Series Switch
Monitoring the Switch
VSP 4900 Switch LEDs
Versatile Interface Modules (VIM5) Port LEDs
Technical Specifications
VSP 4900 Series Switches Technical Specifications
350 W AC Power Supplies Technical Specifications
715 W AC Power Supplies Technical Specifications
1100 W AC Power Supplies Technical Specifications
2000 W AC Power Supply Technical Specifications
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Installing Power Supply Units and Connecting Power
Selecting Power Supply Cords
Battery Notice
Battery Warning - Taiwan
EMC Warnings
Japan (VCCI Class A)
Korea EMC Statement
Follow these guidelines:
Do not try to lift objects that you think are too heavy for you.
When you install equipment in a rack, load heavier devices in the lower half of the rack first to avoid making the rack top-heavy.
Use only tools and equipment that are in perfect condition. Do not use equipment with visible damage.
Route cables in a manner that prevents possible damage to the cables and avoids causing accidents, such as tripping.
Do not place a monitor or other objects on top of the equipment. The chassis cover is not designed to support weight.
To reduce the risk of fire, use only #26 AWG or larger telecommunications line cord. Use only copper conductors.
Do not work on the system or connect or disconnect cables during periods of lightning activity.
This equipment must be grounded. Never defeat the ground conductor or operate the equipment in the absence of a suitably installed ground conductor.
