You can replace fan modules as needed while the switch is operating ("hot swapping").
All installed fan modules must blow air in the same direction and must match the airflow direction of the installed power supplies.
If the switch's fan tray has a red tab, the airflow is front-to-back. Use a fan module labeled Air Out.
If the switch's fan tray has a blue tab, the airflow is back-to-front. Use a fan module labeled Air In.
The operating-system software cannot display the airflow direction.
There are sensors inside the chassis that monitor the temperature. These sensors send information to a controller that automatically regulates the fan speed to maintain the proper temperature.
If any sensor exceeds its threshold, an alarm is triggered and the log is generated in the format:
Temperature Sensor [sensor] is ([sensortemp] C) has exceeded the alarm threshold temperature ([thresholdtemp] C)
where sensor is one of the temperature sensors, sensortemp is the temperature reading of one of the sensors, and thresholdtemp is the threshold temperature.
Temperature Sensor [sensor] overheat temperature alarm cleared
There are ten sensors in VSP 7400-48Y-8C. The following table shows the types of sensors, temperatures, and the corresponding threshold values:
Sensor Name |
Temperature (C) |
Warning Threshold |
Critical Threshold |
INTERNAL MAC |
41 |
100 |
103 |
SODIMM |
15 |
80 |
85 |
CPU |
27 |
65 |
70 |
MAC |
28 |
65 |
70 |
PHY1 |
29 |
65 |
70 |
PHY2 |
25 |
65 |
70 |
PRESS_FIT_CONNECTOR |
29 |
65 |
70 |
MGMT_BRD |
25 |
65 |
70 |
MB |
24 |
65 |
70 |
CPU CORE |
37 |
100 |
110 |
There are ten sensors in VSP 7400-32C. The following table shows the types of sensors, temperatures, and the corresponding threshold values:
Sensor Name |
Temperature (C) |
Warning Threshold |
CPU |
24 |
70 |
75 |
MAC |
39 |
80 |
85 |
PHY1 |
26 |
70 |
75 |
PHY2 |
34 |
70 |
75 |
24 |
70 |
75 |
MGMT_BRD |
27 |
65 |
70 |
MB |
25 |
70 |
75 |
CPU CORE |
29 |
100 |
110 |
INTERNAL MAC |
44 |
100 |
103 |
SODIMM |
15 |
80 |
85 |
Before you begin, have the replacement fan module on hand so that you can complete the replacement promptly. The switch can overheat if left without adequate cooling for an extended time.
To replace the fan module in a switch, do the following.
