Use RJ45 Connector Jackets
Use RJ45 cable with connector jackets that are flush with the connector or that have connectors with a no-snag feature.
Using cable with jackets that are wider than the connectors can
cause:
- Connectors that are not properly aligned with the port.
- Crowded cable installation, which can cause connectors to pop out of the port.
RJ45 Connector Jacket Types shows examples of recommended and non-recommended connector jacket
types.
