Four 750 W power supply units are available for use with VSP 7400 Series switches:
VSP/SLX 750W AC power supply - front-to-back airflow (part no. XN-ACPWR-750W-F)
VSP/SLX 750W AC power supply - back-to-front airflow (part no. XN-ACPWR-750W-R)
VSP/SLX 750W DC power supply - front-to-back airflow (part no. XN-DCPWR-750W-F)
VSP/SLX 750W DC power supply - back-to-front airflow (part no. XN-DCPWR-750W-R)
750 W power supply – AC front-to-back or back-to-front airflow |
Height: 4.00 cm (1.57 in) Width: 8.00 cm (3.15 in) Depth: 20.60 cm (8.11 in) |
750 W power supply – DC front-to-back or back-to-front airflow |
0.81 kg (1.79 lb) |
0.85 kg (1.86 lb) |
Height: 44.5 cm (17.52 in) Width: 27.5 cm (10.83 in) Depth: 42.5 cm (16.73 in) |
10.22 kg (22.53 lb) |
10.50 kg (23.15 lb) |
Voltage input range |
85 to 264 V |
Nominal input ratings |
100-140/200-240V |
Nominal input current at full loads |
10 A at 90 V 3.7 A at 230 V |
Line frequency range |
47 to 63 Hz |
Maximum inrush current |
35 A |
Output |
+12 V, 61.5 A +12 Vsb, 3 A Total output power not to exceed 750W |
Power supply input socket |
IEC 320 C14 |
Power cord input plug |
IEC 320 C13 |
Power cord wall plug |
Refer to Power Cord Requirements for AC-Powered Switches and AC Power Supplies. |
Power supply cord gauge |
18 AWG (0.75 mm2) up to 6 feet or 2 meters or 16 AWG (1.0 mm2) over 6 feet |
Efficiency |
Low Line: 88% at 50% load and 86% at 100% load High Line: 90% at 50% and 100% loads |
Nominal input |
-48 to -60 VDC, 20.4 A |
DC Voltage input range |
-35 to -75 V |
Inrush Current |
21 A peak |
Maximum wire size |
14 AWG (1.5 mm2 copper stranded). |
| DC Output | +12.2VDC, 61.5A; +12Vaux, 2.5A |
Power (W) |
750 W |
Operating temperature |
0°C to 55°C (normal operation) |
Storage temperature |
-40°C to 70°C |
Operating humidity |
20% to 90% relative humidity, non-condensing |
Operational shock |
30 m/s2 (3 G) |
