The front panel of the VSP 7400-48Y switch includes:
48 10/25-gigabit Ethernet ports capable of supporting passive copper SFP28 and active fiber SFP28.
Channelization is not supported on these ports.
Data Ports 55 and 56 are reserved.
RJ45 serial console port used to connect a terminal and perform local management.
USB port for access to external storage.
RJ45 out-of-band 10/100/1000BASE-T management Ethernet port.
LEDs to indicate port status and switch operating conditions. For a description of the LEDs and their operation, see VSP 7400 Series Switch LEDs.
1 = SFP28 Ethernet ports |
3 = USB port |
5 = Management port: RJ45 |
2 = QSFP28 Ethernet ports |
4 = Console port: RJ45 |
6 = Management Set sliding button* |
* - The Management Set sliding button can be slid to the right in order to free the Management Set for removal.
The rear panel of the VSP 7400 switch includes:
Two power supply bays for 750 W AC or DC power supplies.
Six bays for replaceable fan modules.
Red: front-to-back
Blue: back-to-front
The operating-system software cannot display the airflow direction.
1 = Grounding point |
3 = Fan modules |
2 = Power supply slots (unpopulated) |
The power supply slot on the left is for power supply number two and the power supply slot on the right is for power supply number one.
