The ExtremeSwitching VSP 7400 Series includes the following switches:
Specifications for supported power supplies, including dimensions and weights, are found in 750 W Power Supplies Technical Specifications.
VSP 7432CQ switch |
Height: 4.34 cm (1.71 in) Width: 43.96 cm (17.31 in) Length: 53.95 cm (21.24 in) |
| VSP 7400-48Y switch | Height: 4.34 cm (1.71 in) Width: 43.96 cm (17.31 in) Length: 53.95 cm (21.24 in) |
Fan unit, front-to-back or back-to-front |
Height: 4.0 cm (1.57 in) Width: 4.0 cm (1.57 in) Length: 13.4 cm (5.28 in) |
Four-post rack mount kit (included with switch) |
Height: 2.1 cm (0.83 in) Width: 4.4 cm (17.3 in) Length: 63.0 cm - 90.0 cm (24.80 in - 35.43 in) |
Two-post rack mount kit (separately orderable) |
Height: 4.2 cm (1.65 in) Width: 2.4 cm (0.93 in) Length: 12.5 cm (4.92 in) |
VSP 7432CQ switch with no PSUs (base model) |
7.39 kg (16.29 lb) |
VSP 7432CQ switch with two AC PSUs (-F and -R models) |
9.04 kg (19.93 lb) |
| VSP 7400-48Y switch with no PSUs |
| VSP 7400-48Y switch with two AC PSUs (-F and -R models) |
0.14 kg (0.31 lb) |
2.65 kg (5.84 lb) |
0.45 kg (0.99 lb) |
VSP 7432CQ switch |
Height: 18.5 cm (7.28 in) Width: 60.0 cm (23.62 in) Length: 88.0 cm (34.65 in) |
| VSP 7400-48Y switch | Height: 18.5 cm (7.28 in) Width: 60.0 cm (23.62 in) Length: 88.0 cm (34.65 in) |
Height: 24.0 cm (9.45 in) Width: 20.6 cm (8.11 in) Length: 22.1 cm (8.70 in) |
Height: 7.0 cm (2.76 in) Width: 11.0 cm (4.33 in) Length: 84.0 cm (33.07 in) |
14.59 kg (32.17 lb) |
16.24 kg (35.80 lb) |
1.82 kg (4.01 lb) |
2.71 kg (5.97 lb) |
3.20 kg (7.05 lb) |
| Switch Model | Bystander Sound Pressure (at 25°C) | Declared Sound Power (at 25°C) |
VSP7400-32C-AC-F (FB airflow) |
45 db(A) | 6.5 bels |
VSP7400-32C-AC-R (BF airflow) |
47 db(A) | 6.7 bels |
| VSP7400-48Y-8C-F (FB airflow) |
52.2 db(A) | 6.8 bels |
| VSP7400-48Y-8C-R (BF airflow) |
50.5 db(A) | 6.7 bels |
Fan speeds are adjusted based on calculations of the temperatures on all sensors. Due to one fan being located behind the other, air pushed from one fan may cause the other fan in the module to run at a higher speed. One fan can run at medium speed while the other can spin at high speed if one is close to the temperature boundary.
| Description | Operation Status | Operation Speed | Airflow Direction |
| Tray 1 Fan 1 | up | high speed | Unknown* |
| Tray 1 Fan 2 | up | medium speed | Unknown* |
| Tray 2 Fan 1 | up | high speed | Unknown* |
| Tray 2 Fan 2 | up | medium speed | Unknown* |
| Tray 3 Fan 1 | up | high speed | Unknown* |
| Tray 3 Fan 2 | up | medium speed | Unknown* |
| Tray 4 Fan 1 | up | high speed | Unknown* |
| Tray 4 Fan 2 | up | medium speed | Unknown* |
| Tray 5 Fan 1 | up | high speed | Unknown* |
| Tray 5 Fan 2 | up | medium speed | Unknown* |
| Tray 6 Fan 1 | up | high speed | Unknown* |
| Tray 6 Fan 2 | up | medium speed | Unknown* |
* - The color of the tab on the fan tray indicates the airflow direction:
VSP 7432CQ |
750
W AC power supply: Part # XN-ACPWR-750W-F (front-to-back) Part # XN-ACPWR-750W-R (back-to-front) AC Input: 100-120/200-240 VAC, 50/60 Hz 3.5/1.8 A max. for each PSU PSU Input Socket: IEC 320 C14 Power cord input plug: IEC 320 C13 |
| 750
W DC power supply: Part # XN-DCPWR-750W-F (front-to-back) Part # XN-DCPWR-750W-R (back-to-front) DC Input: -48 to -60 VDC, 7.5 A max. for each PSU |
| VSP 7400-48Y | 750 W AC power supply: Part # XN-ACPWR-750W-F (front-to-back) Part # XN-ACPWR-750W-R (back-to-front) AC Input: 100-120/200-240 VAC, 50/60 Hz 3.5/1.8 A max. for each PSU PSU Input Socket: IEC 320 C14 Power cord input plug: IEC 320 C13 |
| 750
| Operating Mode | Test Conditions | Power Consumption | |||||
| Fan Duty | Traffic Load | Port Status | Packet Length (Bytes) | Dual Power: PSU1 | Dual Power: PSU2 | Single Power: PSU1 | |
Empty mode |
85% |
NA |
Down |
NA |
152.6 W |
145.5 W |
285.9 W |
Standby mode |
85% |
NA |
Up |
NA |
157.6 W |
151.5 W |
297.2 W |
Typical mode |
85% |
70% |
Up |
1,518 |
165.0 W |
159.8 W |
313.6 W |
Stress mode |
100% |
100% |
Up |
256 |
207.8 W |
204.5 W |
406.0 W |
Empty mode |
85% |
NA |
Down |
NA |
92 W |
87 W |
170 W |
Standby mode |
85% |
NA |
Up |
NA |
97 W |
91 W |
178 W |
Typical mode |
85% |
70% |
Up |
1,518 |
104 W |
99 W |
193 W |
Stress mode |
100% |
100% |
Up |
256 |
199.8 W |
186.2 W |
387 W |
| Switch | Mean Time Between Failures |
| VSP7400-32C-8C-AC-F | 384936 hrs @ 25°C |
| VSP7400-32C-8C-AC-R | 444822 hrs @ 25°C |
| VSP7400-48Y-8C-AC-F | 389719 hrs @ 25°C |
| VSP7400-48Y-8C-AC-R | 450269 hrs @ 25°C |
| 1GHz 64-bit CPU |
| 16 Gb memory, 128 Gb SSD |
| 4GB eMMC Flash Memory |
| 32 MB buffer, per chip |
North American Safety of ITE |
UL 62368-1 2nd Ed., 2014-12-01, Listed Device (US) UL 60950-1 2nd Ed., 2014-10-14, Listed Device (US) CAN/CSA 22.2 #62368-1-14 2nd Ed., Canada CAN/CSA 22.2 #60950-1-07 2nd Ed., Canada 2014-10 Complies with FCC 21 CFR Chapter 1, Sub-chapter J in accordance with FDA & CDRH requirements (US Laser Safety) CDRH Letter of Approval (US FDA Approval) |
European Safety of ITE |
EN 62368-1:2014/A11:2017 EN 60950-1:2006 + A11:2009 + A12:2010 + A2:2013 2014/35/EU Low Voltage Directive |
International Safety of ITE |
CNS 14336-1 AS/NZX 60950-1 (Australia /New Zealand) GB4943.1-2001 IEC/EN 60825-1:2007, IEC/EN 60825-2:2004+A1+A2 or later (Lasers Safety) IEC 62368-1:2014 (2ndEd.) IEC 60950-1:2005 (2nd Ed.) + Am 1:2009 + Am 2:2013 + National Difference |
North America EMC for ITE |
European EMC standards |
International EMC certifications |
Country-specific |
EN/ETSI 300 386:2008 (EMC Telecommunications) EN/ETSI 300 019 (Environmental for Telecommunications) MEF9 and MEF14 certified for EPL, EVPL, and ELAN |
IEEE 802.3ab 1000BASE-T IEEE 802.3z 1000BASE-X IEEE 802.3ae 10GBASE-X IEEE 802.3ba 40GBASE-X |
Environmental standards |
EN/ETSI 300 019-2-1 v2.1.2 (2000 - 2009) - Class 1.2 Storage EN/ETSI 300 019-2-2 v2.1.2 (1999 - 09) - Class 2.3 Transportation EN/ETSI 300 019-2-3 v2.1.2 (2003 - 04) - Class 3.1e Operational EN/ETSI 300 753 (1997-10) - Acoustic Noise ASTM D3580 Random Vibration Unpackaged 1.5G |
Temperature range |
Other operating conditions |
Humidity: 5% to 95% relative humidity, non-condensing Altitude: 0 to 3,000 meters (9,850 feet) Operational shock (half sine): 30 m/s2 (3 G), 11 ms, 60 shocks Operational random vibration: 3 to 500 Hz at 1.5 G rms |
Storage & transportation conditions (packaged) |
Transportation temperature: -40°C to 70°C (-40°F to 158°F) Humidity: 5% to 95% relative humidity, non-condensing Packaged shock (half sine): 180 m/s2 (18 G), 6 ms, 600 shocks Packaged sine vibration: 5 to 62 Hz at velocity 5 mm/s, 62 to 500 Hz at 0.2 G Packaged random vibration: 5 to 20 Hz at 1.0 ASD w/–3 dB/oct. from 20 to 200 Hz 14 drops minimum on sides and corners at 42 in (<15 kg box) |
