The following tables describe the meanings of the LEDs on the front panel of the VSP 7400 Series switch:
| Port Configuration | Color/State | Meaning |
| 100 Gb or 4x25 Gb |
Steady green | Port OK |
| Blinking green | Port transmitting or receiving | |
| Slow blinking green | Port disabled by software | |
| Off | No link/Fault | |
| 40 Gb or 4x10 Gb |
Data Ports 55 and 56 are reserved.| Port Configuration | Color/State | Meaning |
| 10/25 Gb | Steady green | Port OK |
| 100 Gb or 4x25 Gb |
| 40 Gb or 4x10 Gb |
| Label or Type | Color/State | Meaning |
| PSU1,PSU2 (Power Supplies) |
Steady green | PSU is installed and providing power |
| Steady amber | PSU is installed but input power is disconnected or unit fault detected | |
| Off | PSU is not installed | |
| FAN | Steady green | All fans operating normally |
| Steady amber | A fan has been removed or fault detected | |
| Off | No power to fan modules | |
| SYS (System) |
Steady green | Normal operation; agent software code has been loaded |
| Blinking green | Loading the agent software code | |
| Steady amber | Error encountered while running diagnostic software | |
| Blinking amber | Loading and executing the boot loader or diagnostic software | |
| Off | Unit not operational | |
| PWR (Power) |
Steady green | Normal operation |
| Blinking green | System in reset | |
| SYS (System) |
| PWR (Power) |
| OOB Management Port (Link/Activity) |
Steady green | Network link |
| Blinking green | Network link and activity | |
| Off | Link at 10Mbps or no activity | |
| OOB Management Port (Speed) |
Blinking green | Port link at 100Mbps |
| Steady green | Port link at 1000Mbps | |
| Off | Link at 10Mbps or no link |
