To attach a switch to a four-post or two-post rack, follow the steps in the appropriate section:
When you install Extreme Networks switches, we recommend that you have two people to maneuver the switch and the mounting hardware.
Take care to load the rack so that it is not top-heavy. Start installing equipment at the bottom and work up.
After the switch is attached to the rack, refer to Remove the Switch from the Rack if you need to remove it.
