Connect the Switch to a Management Console
Connect each switch's serial console interface (an RJ45 jack) to a PC or terminal. The PC or terminal will serve as the management console, used to monitor and configure the switch.
The default communication protocol settings for the serial console interface are:
- Baud rate: 115200
- Data bits: 8
- Stop bit: 1
- Parity: None
