Preparing the Cables for a 750 W DC Power Supply
You will need three cable wires for
each installed DC power supply: two input cables and a grounding cable. We recommend
that each cable have differently colored insulation, as described in Required Tools and Materials for Installing a 750 W DC Power Supply.
To prepare the cable wires, follow these steps:
- On each cable wire, strip 6 mm (0.25 inch) of insulation from one end.
- Repeat step 1 for the other two cable wires.
