Activating and Verifying the Switch
After you have installed the switch and connected network cables, perform the following tasks to configure the software on the switch and prepare it for use.
Check https://www.extremenetworks.com/support/compatibility-matrices/extremecloud-hardware-support/ to see what switch models can be managed with ExtremeCloud™. If your switch is entitled for management by ExtremeCloud, you can optionally use the installation instructions at https://documentation.extremenetworks.com/extremecloud/quick_reference.
Otherwise, follow the instructions in these topics:
