After your switch is connected to power and completes its power-on self-tests, it is
operational. Before logging in, verify that the switch LEDs are on (solid green or
blinking green) and that it is connected to a management console as described in
Connect the Switch to a Management Console.
To perform the initial login and complete initial configuration tasks, follow these
steps from the management console.
Using a terminal emulator such
as PuTTY or TeraTerm, connect to the switch using the serial port
connection.
Be sure that your serial
connection is set properly:
- Baud rate: 115200
- Data bits: 8
- Stop bit: 1
Press [Enter] one or
more times until you see the login prompt.
At the login prompt, log in
using the default user name rwa.
When prompted for the password,
enter rwa.
When you are logged in with the role-based authentical level of rwa, you can
configure the login and password values for the other role-based
authentication levels. For details, see Quick Start Configuration
for VOSS.
Follow the steps for
provisioning and verifying the switch in Quick Start Configuration for
VOSS.
The switch is ready for use.
To configure security, see Configuring Security.
To configure other switch features, see Documentation Reference.
