List of Installed and Active Features
Multiple features are installed with OneController. Several of these features are also active (functioning). You can make installed, but inactive, features active (see Karaf Overview)
The following table lists all OneController installed features, and indicates which ones are active by default (✓ in Active column).
Feature | Description | Active |
AAA | Authentication, Authorization, and Accounting | ✓ |
ADSAL | API Driven Service Abstraction Layer | ✓ |
ARP Manager | Address Resolution Protocol Manager | ✓ |
BGP | Border Gateway Protocol | |
Controller | OpenDaylight Controller and its Config Plugins | ✓ |
COPS | Common Open Policy Service | |
DLUX | Web UI with Extreme Networks Platform Manager | ✓ |
Felix | OSGi Dependency Management | ✓ |
FRM | Forwarding Rules Manager | ✓ |
GBP | Group-Based Policy | |
Gemini Web | OSGi Web Container | ✓ |
Host Tracker | Catalogs Hosts in the Network | ✓ |
Jackson JAX RS | Java Data Parsing Tools | ✓ |
Jersey | RESTful Web Services framework | ✓ |
Jetty | Java Servlet Container | ✓ |
LISP | Locator/Identifier Separation Protocol | |
MDSAL | Model Driven Service Abstraction Layer | ✓ |
MDSAL API Docs | API Explorer based on Swagger | ✓ |
NETCONF | Network Configuration Protocol | ✓ |
Netty Config | Netty.io Configuration API | ✓ |
OpenFlow | OpenFlow Protocol Plugins | ✓ |
OVSDB | Open vSwitch Database Protocol | |
PCEP | Path Computation Element Communication Protocol | |
Platform Manager | OneController Platform Manager API | ✓ |
Plugin2OC | Plugin to OpenContrail | |
RESTConf | REST API for accessing YANG / NETCONF | ✓ |
SDNI | SDN Interface (Cross-Controller Federation) | |
SFC | Service Function Chaining | |
SLF4J Logging | Simple Logging Façade for Java | ✓ |
SNBI | Secure Network Bootstrapping Infrastructure | |
SNMP | Simple Network Management Protocol | |
Spring | Spring Dependency Injection Framework | ✓ |
Stats Manager | Send Statistics Requests to OpenFlow Nodes | ✓ |
Switch Manager | Catalogs Capabilities of Network Elements | ✓ |
Tomcat | Java Servlet Container | |
Topology Manage | Network Topology Manager | ✓ |
TTP | Table Type Patterns | |
VTN | Virtual Tenant Network | |
YANG | Tools for YANG models | ✓ |
