Using OneController Interfaces
OneController has the following interfaces.
Name | Speed | |||
OneC-V | OneC-A-600 | OneC-V | OneC-V | Purpose |
Admin | Eth0 | 1 GbE | 10Gbps | Management |
Esa0 | Esa0 | 1 GbE | 10Gbps | Data |
Esa1 | Esa1 | 1 GbE | 10Gbps | Data |
— | Esa2 | 1 GbE | 10Gbps | Data |
Ideally, you should have a dedicated management physical network or VLAN, which you connect to Admin/Eth0.
Generally, Esa0–2 interfaces should be used to connect OneController to your OpenFlow-capable switches for control communications and data traffic (see Using OpenFlow).
