Viewing OneController Reports
OneController provides system and manufacturing information reports about itself.
To view OneController reports:
  1. On the left navigation bar, click System Configuration, and then, on the menu bar, click Reports. The Report screen appears (see the following figure).
    expand icon
    Report Screen—System Information Report
    Graphics/OneC_Reports_System_Info.png
    The System Information report appears by default showing:
    • System up time
    • Memory usage
    • Disk usage
    • Interface information
  2. To view the Manufacturing Information report, select Manufacturing Information from the Report list. The Manufacturing Information report appears (see the following figure).
    expand icon
    Report Screen—Manufacturing Information Report
    Graphics/OneC_Reports_Manufacuturing_Info.png
    The Manufacturing Information report displays the following information:
    • Software version
    • Extreme Networks ODL build version (build number for the Java/ODL part of OneController)
    • Model type: OneC-V (virtual machine) or OneC-A-600 (hardware appliance)
    • CPU type and speed
    • If hardware encryption is supported
    • ESA0, ESA1, and management port MAC addresses
