Feature Compatibility
The following tables lists the contents of the OpenDaylight compatible-with-all integration test.
OpenDaylight Compatible-with-All Test Contents
odl-aaa-all | odl-openflow-nxm-extensions | odl-sfclisp |
odl-aaa-authz | odl-openflowjava-protocol | odl-sfcofl2 |
odl-adsal-all | odl-openflowplugin-flow-services | odl-snbi-all |
odl-adsal-compatbility | odl-openflowplugin-flow-service-rest | odl-ttp-all |
odl-bgpcep-all | odl-openflowplugin-flow-service-ui | odl-snmp4sdn-all |
odl-dlux-core | odl-ovsdb-all | odl-tcpmd5-all |
odl-listflowmapping-all | odl-packetcable-all | odl- |
odl-mdsal-broker | odl-sdninterfaceapp-all | odl- |
odl-netconf-connector-ssh | odl-restconf | odl- |
odl-nsf-all | odl-sfc-all | odl- |
There are six modules that the OpenDaylight community test independently against compatible-with-all, but not against each other. The following table lists whether these modules are compatible, incompatible, or compatibility is unknown.
Integration Test Feature Sets
GBP | L2switch | Open Contrail | OVSDB OpenStack | OVSDB SFC | VTN Manager | |
Compatible-with-all | Compatible | Compatible | Compatible | Compatible | Compatible | Compatible |
L2switch | Unknown | — | — | — | — | — |
Open Contrail | Unknown | Unknown | — | — | — | — |
OVSDB OpenStack | Unknown | Unknown | Unknown | — | — | — |
OVSDB SFC | Unknown | Unknown | Unknown | Unknown | — | — |
VTN Manager | Unknown | Incompatible | Unknown | Unknown | Unknown | — |
