Verifying OpenFlow Configuration and Operation
You can verify the OpenFlow setup using the following commands.
To verify that OpenFlow is enabled correctly on the switch, type:
show openflow
The following sample output of the command shows that the switch has OpenFlow enabled, that FDB is on, and that the ACL width is double.
* (Private) SDN-1.1 # show openflow
OpenFlow:          Enabled
Versions:          OpenFlow10, OpenFlow13
Mode:              Standard
FDB:               On
Access-list width: Double
Controller       : Primary
    Status       : ACTIVE
    Datapath ID  : 00000004968374d4
    VR           : VR-Default
    Mode         : out-of-band Active
    Target       : tcp:10.66.65.242:6633
    Uptime(secs) : 1134555
Controller       : Secondary
    Not configured.
                                            Flows
VLAN                             VID  Ports Active Error
major                            4089     3      2      0
Total number of VLAN(s): 1
To verify the setup of OneController on the switch, type:
show openflow controller {primary | secondary}
The following sample output of the command shows that the switch has a primary OneController (but no secondary controller), located at 10.66.65.242, and that it is communicating with OneController through the virtual router "VR-Default."
* (Private) SDN-1.2 # show openflow controller
    Configured   : Yes
    VR           : VR-Default
    Status       : ACTIVE           TLS              : Disabled
    Probe(secs)  : 30               Uptime(secs)     : 1135034
    Rate Limit   : 1000             Burst Size       : 250
    Packets Sent : 348705           Packets Received : 274586
    Configured   : No
To view the number of flows on the switch so that you can ensure that it is not exceeding the capacity of the switch, type:
show openflow flows
The following sample output of the command shows that the switch has two flows.
* (Private) SDN-1.3 # show openflow flows
Total number of flows: 2
Flow name     Type Duration (secs)     Prio  Packets
of_48         ACL               172915    10               172913
    Match:   Input Port:         14
             Src MAC:            00:0c:29:02:10:d3
             Dst MAC:            00:0c:29:80:ac:0a
             Ethernet Type:      0x0800
    Actions: output:10, cookie:0x20000000000000, idle:5:4
of_49         ACL               172915    10               172913
    Match:   Input Port:         12
             Src MAC:            00:0c:29:80:ac:0a
             Dst MAC:            00:0c:29:02:10:d3
    Actions: output:14, cookie:0x20000000000000, idle:5:4
