OSPFv3 areas
You can assign only one area on a device interface.
You are required to configure a router ID when running only IPv6 routing protocols.
By default, the router ID is the IPv4 address configured on the lowest-numbered loopback interface. If the device does not have a loopback interface, the default router ID is the highest-numbered IPv4 address configured on the device. You can also configure router id using the ip router-id command.
