  1. Access global configuration mode.
    device# configure terminal
  2. Enter IS-IS router configuration mode and enable IS-IS on the device.
    device(config)# router isis
  3. Disable partial SPF optimizations.
    device(config-isis-router)# disable-partial-spf-opt
